Battery fuel gauge recommendation
Other Parts Discussed in Thread: BQ27Z561-R2, BQ35100, BQ27426, BQSTUDIO, EV2400, GPCCHEM
1,Battery voltage:4.1V;
2,Capacity:220mAh;
3,Output current:0.1mA--100mA;
4,The sense resistor:10--50mΩ,decided by the design desirment;
5,The battery will be enclosed into a metal case and will be implanted into the human body,the case can't be open again after implanting to calibrate the battery;
6,We want you to help us to choice one Battery fuel gauge that suite for our design needs,the capacity of the battery parameter should be more precise and correct;
7,How to use the Battery fuel gauge and how to make the fireware and how to calibrate before SMT on the PCB board?
8,What tools we need to fully use the Battery fuel gauge?
+86-18857893398
