DS describes enable pin use external open-drain control, could you help to check the circuit (Figure 1) is ok for you ?
Since internal is current source pull-up, will it damage the enable pin if enable pin tie to GND directly ?
Hi, no damage happen when enable pin tie to GND directly.
Yuchang
