We are using TPS543B20 sense regulator for voltage conversion from 12V to 1.1V in non-stackable mode. We would like to know whether ENABLE pin is open drain or push-pull, in datasheet it is mentioned as ENABLE Pin has an internal pull up, we want to know about the internal pull up value.
We would also like you to ensure/ review the below schematic design for the conversion.
S Sathya shree
