TPSM82823: Layout pattern
Part Number: TPSM82823
Hi team,
My customer is tring to use TPSM82823SILR, then we have below 2 questions.
- FB signal through Via
Now they're thinking FB signal is through Via and and connected with R and C at back side, because they don't have many experience of wiring under ceramic condenser.
Can you give us your insigt of concern or recommendation of wiring?
- Datasheet Rev.A --> Rev.B of TPSM8282xEVM-080
Customer can see reccomed pattern difference Rev. A and B, like Rev.A doesn't have a wiring under bypass capacitor.
Why did you have this change? Or do you have any concern to use Rev.A pattern?
Kento
  • Hi Kento,
    Both revision A or B of the TPSM8282xEVM-080 can be used. The FB signal can be routed through a via like in rev. A.
    Revision B was created for better EMI and thermal performance and to also highlight a smaller solution size.
    Varun
