Other Parts Discussed in Thread: TPS23753, , TPS2372, TPS2373
Hi Sir,
Customer is testing TPS23753's power source changing function. They set up their board by following application note:
At their testing, when plugging POE source, there's a Vout drop.
Ch1: Vout 5V,
Ch2: VDD-VSS
Ch1: GATE
Ch2: VC
Ch3: Vout 5V
Using option2 at following link has similar result.
https://www.ti.com/lit/an/slva306a/slva306a.pdf
Customer want to confirm is the output drop is always happened? Or how to modify TPS23753A circuit to prevent the voltage drop? Any other chip can change power source from adaptor to POE smoothly? Thanks for your kindly help.
Gary Teng
