UCD3138: UCD3138 CRC Response
Part Number: UCD3138
For UCD3138 what poly and initial CRC value are used for CRC calculation?
    What does the CRC calculation use for?
    For UCD3138, we just have the CRC calculation for PEC in PMBus.
    Xuemei
  • Hi and thank you for your kind reply
    My problem is  I am reading UCD3138 with an USB to I2C converter I have build myself via I2C bus and
    getting the Vin Vout etc correctly.
    Now I want to program the limits etc on the chip and for that I need to calculate CRC8.
    Using CRC8 online calculators https://crccalc.com/ I find the CRC8 for say 0XDAD1 which is the value displayed on
    Texas Fusion Design On line program for a value of  22.53A to be  0x01 for poly = 07 and crc initial =0
    the program displays different crc for different combination of poly and initial crc a total of 10 including
    that of MAXIM and ROHC etc and than with a TI USB interface Adaptor connected to UCD3831
    I am monitoring the I2C bus  with an oscilloscope and I see that the CRC8 byte send by the Fusion Design On line program
    is 0XBC which does not match to any of the results I get from online crc calculator
     and I have also written a program on visual studio to calculate the CRC myself and my results match that of the on line
    Crc calculation program . So I would kindly like to know how TI calculates CRC. If a table is used for CRC calculation could I receive it
    Kind Regards
    You could take a look at our PFC demo code, in which a PEC calculation algorithm is described. This is what UCD3138 used. It shall be in pmbus_common.c as shown below.
    PFC demo code: https://www.ti.com/tool/UCD3138FW-PFC?keyMatch=UCD3138%20PFC
    Xuemei
