Other Parts Discussed in Thread: USB2ANY, USB-TO-GPIO2
Good evening,
I am an FPGA delevoper. I'm using the Xilinx evaluation board ZC702 that features UCD9248 digital power controllers.
I need to reprogram one of the output voltages from 2.5 V (default) to 3.3 V.
I am using the "fusion design" flow and following the istructions found on the online guides, but it is not working.
I connected the USB2ANY TI component to my PC and to the XIlinx evaluation board port j59 as suggested, removed the j12 jumper on the evaluation board and then turned on the board.
But I always get "no USB Adapet Found!" alert on Fusion Digital Power Designer GUI.
Where can the problem be?
Thank you for your answer
Lorenzo D'Antonio
