TLC5922: The Formula for Calculating Power Consumption
Part Number: TLC5922
Dear Specialists,
My customer is considering TLC5922 and has a question.
I would be grateful if you could advise.
---Question
Could you provide ideas and formulas for calculating the power consumption.
I couldn't find any information in the datasheet.
Also, if there is a maximum value and a coefficient to be used in actual use, please provide it.
I appreciate your great help and cooperation.
Shinichi
  • Hi Shinichi,
    Nice to hear you.
    For the power consumption, I guess they want to know how to calculate the temp rise of the device.
    So, they can take bellow document as reference:
    Semiconductor and IC Package Thermal Metrics (Rev. C) (ti.com)
    Besides, this device is very old one, and we have many new devices also support 16 channels control, do they have some special requirement for TLC5922?
    If not, I would like recommend you some new devices with better supply condition.
    Thanks!
    Ives Li
  • Hi Ives,
    Thank you for your reply.
    In this case, the customer'd like to calculate the power dissipation of the device.
    The TLC5922 is a sink type LED driver.
    Regarding the loss budget, I think as follows.
    I'd like you to check and advise.
    ・Pout  Power of OUT pin The value obtained by subtracting the VF of the LED from VLED is given to the OUT pin.
    The value obtained by multiplying that value by the sink current is the loss.
    (VLED-VF)×Isink
    Multiply by the number of Ch.
    Pout=(VLED-VF)×Isink x ch number
    Apply duty according to usage conditions
    ・Consumption of the device itself
    Supply voltage VCC multiplied by ICC.
    Pdevice=VCCxICC
    Ptotal=Pout+Pdevice
    Please provide any application notes that illustrate power loss about sink type LED drivers.
    Shinichi
  • Hi Shinichi,
    Yes, your understand about power dissipation is correct.
    But still need to pay attention on PCB layout, which plays an important role in temp rise.
    Thanks!
  • Hi Ives,
    You're right, I think the heat generation will change depending on the layout of the board.
    I'll share the application note you attached and tell them to pay attention.
    Shinichi
  • Hi Shinichi,
    You are welcome, please let me know if you have any questions.
    Thanks!
    Ives Li
