Part Number: TPS6594EVM
Hi TI Engineer,
I have some questions regarding the GUI NVM code and device NVM as below.
1. Is the TPS65941111 NVM code template in GUI the same as NVM code in TPS65941111 device?
2. Is the TPS65941212 NVM code template in GUI the same as NVM code in TPS65941212 device?
3. Is the TPS65941213 NVM code template in GUI the same as NVM code in TPS65941213 device?
I'm trying to repogram the device I have TPS65941111 + TPS65941212 to TPS65941111 + TPS65941213, but I notice that TPS65941111 configuration in GUI template is different from TPS65941111 code I read from device. Why is that? Should I use the GUI template of TPS65941111 + TPS65941213 to reprogram TPS65941111 + TPS65941212 devices?
Thank you,
Charlotte
