Hi team,
2-V power supply, the output voltage should be 3.3 V at power up, but the actual output is around 0.8 V. The test found that 1-pin VCC was shorted to 5pin, 6-pin GND. This is not the case for all boards, some of boards have this issue.
Could you help check this case? Thanks.
Cherry
