Part Number: TPS65982
Hi Team,
When the customer was doing the test, he suddenly found that the retest rate was very high. Later, it was found that compared with the past code, he lost to add a Reset operation of this chip (TPS65982ABZBHR). Use this chip to perform some GPIO operations, it will not work without adding Reset, and it will be fine after adding Reset. Then he captured the waveforms on these GPIOs and found that there is no problem, and the IO status is good. So he wants to know whether the underlying code of Reset includes other things?
Annie Liu
