We are testing the BUCK IC TPS560430YQDBVRQ1, but it is not providing fixed output with load. Output voltage is DIP for load current.
The circuit is designed on WEBENCH according to the 12V input supply for 300mA load with 5V output.
Hello
Please provide you actual circuit schematic.
Be sure that your input supply is not current limiting.
What load do you see the output voltage deviating ?
How much is the output voltage deviating ?
Please provide waveforms of the output voltage and SW node during your test.
Hi
Requirement: - voltage=12V output voltage=4.85V and load current =160mA (30 Ohm)
This is switching voltage and output voltage graph for 160mA load current, but output is dip up to 4.3V.
Hello
Try shorting out D5 and test again.
Please provide images of your PCB layout.
I already short the diode but still not getting proper result.
PCB is under process i made this circuit on zero PCB.
