Dear team
I have a question over the NTC pin.
If the NTC pin is pulled down due to high input voltage (used for overvoltage protection), when the input voltage back to normal again, NTC is pulled high but will the controller run the start-up process automatically?
From my perspective, once the NTC is pulled low, it shuts down the controller. The supply voltage on VDD is going down to zero. When NTC is pulled high, the controller will run the start-up process.
Could you help me clarify it?
Best regards
Mingxiao Li
