TPS50601-SP: TPS50601-SP Worst Case Model
Part Number: TPS50601-SP
Other Parts Discussed in Thread: TPS50601A-SP,
I am using the TPS50601-SP AVG TINA model to find the phase and gain margin but I am unable to measure the gain margin. I found a TPS50601A-SP Worst Case Analysis Unencrypted model in which I was able to simulate and measure the gain margin. Using the same circuit, I tried the same measurement with the regular TPS50601A-SP model and was unable to measure the gain margin. I am assuming I need a worst case analysis model for the TPS50601-SP in order to measure the gain margin.
 I'm not sure if the TPS50601-SP has a worst case model, but if so is it available?
Thanks in advance!
  • Hi Robert,
    Could you share your simulation files or at least screenshots of your schematic and measurement results so I can see how you have it set up? Both the Average and WCA models are capable of providing full frequency response results.
    Regarding the question about the TPS50601-SP, there is not a WCA model for this device.
    Sarah
