LM5045: Can LM5045 single group drive two MOS transistors
Part Number: LM5045
HI
Can LM5045 single group drive two MOS transistors, MOS tubes in parallel; Thanks!
  • Hi. It depends on what kind of MOSFETs you will be driving. The gate drivers integrated in this chip (low side and high side) can provide a sink current up to 2A (Datasheet pg.9). So, depending on how large are the gate to source capacitors of your MOSFETs, it will require different level of currents.
