I tried to simulate 1.2V and 3.3V supply from 5V input in TINA simulation.
however I am getting 5V in the output. Can you please look into this and guide further? Please let me know if any other details are required.
Hello Darshankumar,
Thank you for using E2E.
Can you please use the PSpice model which is available here - TPS62420 data sheet, product information and support | TI.com
you can run the simulation my using PSpice of TI which is available here - PSPICE-FOR-TI Simulation tool | TI.com
Thank you & regards,
Moheddin.
I am looking for integrating some other simulations with this IC which are already there on TINA. can you please look into attached simulation and suggest?
Hello Darshankumar,
I checked the simulation model of TINA and I see the same error, there should be some problem with the model because not all the PSpice model works in TINA. I would recommend to use the PSpice model since TINA is not supported by TI anymore.
I also simulated the PSpice model and didn't find any concern, most of the PSpice model of the TI devices will be available in ti.com, I would recommend to PSpice for TI for integration and simulation.
Moheddin.
