TPS25750EVM: EEPROM initial value on EVM (binary file)
Part Number: TPS25750EVM
Other Parts Discussed in Thread: TPS25750
Hi, Team.
How can I read the EEPROM initial values on the EVM in binary using the TPS25750 Application Customization Tool?
Please let me know if there is another way to get it.
Because I want to return to the original state after customizing the settings.
Thank you.
  • You cannot import a raw-EEPROM binary and revert the settings in the Application Customization Tool.
    You can read-back the full EEPROM memory and save what is loaded in the EEPROM right now. Using any flash utility you should be able to read-back the binary and use the 'Flash To Device From Binary File' option.
    Hope this helps!
    Chris
