Hi Jeff:
Hello, I have some questions about pre charging that I would like to consult with you
Q1:My battery voltage is 4.4V/2A, and the pre charging voltage set is below 3V to start pre charging. But when my battery voltage just drops below 3V, the charging current will jump, not the set 200mA, until it stabilizes at around 2.7V. Is this normal?
Q2:May I ask if there is any way to solve this problem (current jumping during the conversion process from fast charging to pre charging)? I want to switch to 200mA pre charging immediately after the battery voltage drops below 3V. If you have any good suggestions, could you please guide me
