Other Parts Discussed in Thread: LM3642
Hi Team,
just want to check on what's the difference between below two parameters? what does it means " device not switching pass mode" ? Thanks.
BRs
Given
Hi Given,
May I know where these two data come from? I can't find related info in LM36274 datasheet.
BR
Patrick
Hi Given,
I_SB means that the input standby current while the Mode Bits Bit0&Bit1 of Enable Register <0x0A> is 0x00.
I_Q means that the quiescent current while device is enabled but the output voltage doesn't require the device to switch.
BR, Jared
