Hi Team,
When the VIN pin has a voltage input, the output is no-load,
Float the EN pin to measure the voltage value,
will measure 5 volts,
Is this phenomenon normal?
Hi Team,
Hi Kevin,
It should be normal. EN-pin has internal pull-up to internal reference. Float this pin will enable the device.
