Other Parts Discussed in Thread: BQSTUDIO, GPCRA0
Hi team,
Our customer is having a problem with getting the UpdateStatus to change from 0x00 to 0x04 at the start of the learning cycle test. Please see procedure below:
- Performed the IT_Enable command
- Performed the RESET command
- Pressed Start Log and created a saved filename
- went to the Learning Cycle tab and began a manual operation
- Turned on the constant current C/5 load for discharge
I don’t believe I missed a step from this document: https://www.ti.com/jp/lit/an/slua903/slua903.pdf?ts=1686040068138&ref_url=https%253A%252F%252Fwww.ti.com%252Fsitesearch%252Fja-jp%252Fdocs%252Funiversalsearch.tsp%253FlangPref%253Dja-JP%2526searchTerm%253DSLUA903%2526nr%253D208&_ticdt=MTY4OTU5ODIzMnwwMTg1OTdlNDQ3OWYwMDRjNWM4YmFhYTUyYmM4MDUwNmEwMGZiMDYyMDA5Nzh8R0ExLjIuMTkxNzM0Mzk2Mi4xNjczMjkwNTk5
I tried UNSEAL and reissuing the first two commands, but I don’t see a UpdateStatus change. What have I missed?
The IT_Enable and RESET commands read N/A in bqStudio transaction log.
Ben
