I have downloaded Android Gingerbread 2_3_4source from TI site.
I am trying to build the kernel, but i am getting an error message when building the kernel.
CHK include/generated/compile.h
GEN .version
UPD include/generated/compile.h
CC init/version.o
LD init/built-in.o
LD .tmp_vmlinux1
drivers/built-in.o: In function `composite_unbind':
/home/guest/rowboat-android/TI_Android_GingerBread_2_3_4Sources/kernel/drivers/usb/gadget/composite.c:1205:
undefined reference to `switch_dev_unregister'
/home/guest/rowboat-android/TI_Android_GingerBread_2_3_4Sources/kernel/drivers/usb/gadget/composite.c:1206:
drivers/built-in.o: In function `composite_switch_work':
/home/guest/rowboat-android/TI_Android_GingerBread_2_3_4Sources/kernel/drivers/usb/gadget/composite.c:1239:
undefined reference to `switch_set_state'
/home/guest/rowboat-android/TI_Android_GingerBread_2_3_4Sources/kernel/drivers/usb/gadget/composite.c:1247:
drivers/built-in.o: In function `composite_bind':
/home/guest/rowboat-android/TI_Android_GingerBread_2_3_4Sources/kernel/drivers/usb/gadget/composite.c:1300:
undefined reference to `switch_dev_register'
/home/guest/rowboat-android/TI_Android_GingerBread_2_3_4Sources/kernel/drivers/usb/gadget/composite.c:1304:
make: *** [.tmp_vmlinux1] Error 1
need help in resolving the above issue.
Prajith
