Other Parts Discussed in Thread: UCC28070
Hello Sir,
Can you please Validate my design sheet of UCC28070 for 1 KW Converter. I want to make it. 8867.UCC28070 Design Tool _RevA.xls
Hello Sir,
Hi Aaqib,
Thank you for the query on UCC28070.
I checked the sheet and most of it looks fine.
It would be better if you change the following to the recommended values:
1. Rsa, Rsb to 41ohm as it better in full scale accuracy.
2. RDMX needs to be selected according to the required Dmax value. For 0.94 use the correct value recommended.
3. Rimo seems to be lot of difference. Please stick with the tool recommended values, else choosing a higher value will produce more output power.
4. Also the please choose the compensation values for current loop/ voltage loop as close as possible to calculated values.
Please let us know if you have further questions.
Harish
There are lot of CT options. Please refer the coilcraft website link below:
https://www.coilcraft.com/en-us/tools/current-transformer-selector/#/results
Also, please refer to the equations for Lm in the following app note before selecting CT and make sure Volt-sec product is satisfied. This mentioned in datasheet. (pages 33 & 34)
Harish
