TPS631000: Switching from PFM to PWM
Part Number: TPS631000
Hi Team,
With the regulator enabled and stable input supply. How long will it take for the buck-boost to transition from PFM mode to PWM mode from the time MODE pin changes state?
Need to be in PFM mode while in essentially a standby output load and then transition to PWM before load transient because of the desire for a predictable Fsw when at max load.
Thank you,
Trenton Reed
