Part Number: UCC23514
Other Parts Discussed in Thread: UCC5310
Hi all,
I'm using the following scheme to provide noise immunity to the drive signal path. The drive signal is quite critical and false triggering must be kept to a minimum.
Is this a appropriate method? Is there a better or more standard way to drive reduce noise for gate drivers? LVDS differential voltage level seems to be quite low (350 - 400mV swing) which could be affected by a very noisy environment?
