TPS2115A: USB POWER Switch
Part Number: TPS2115A
Hi
USB POWER SWITCH ( adjustable current + OVP ) Requirements: Regardless of whether it is turned on or off, it must have a reverse cut-off function to prevent reverse backflow USB PORT can be used alone and only needs 1.XA current
Does the 2:1 MUX come with a built-in reverse cut?
For example the following ??
https://www.ti.com/lit/ds/symlink/tps2115a-q1.pdf?ts=1691121276001&ref_url=https%253A%252F%252Fwww.ti.com%252Fproduct%252FTPS2115A-Q1%253Fqgpn%253Dtps2115a-q1
