Hello
What is the logic low level threshold voltage of FLT & RDY Pin ? is it same as VODL (Open drain low output voltage) given in the datasheet ?
Thanks and Regards
Anoop kumar
Hello
Thanks and Regards
Anoop kumar
Hi Anoop,
Yes that is correct, that is the minimum voltage required for a 5mA IODON to pull the FET low and trigger the nFLT and pull RDY pin low.
Pratik
