Hello team,
When we want to set 10mA as charging current, how value is right as RSR?
Shotaro
Hello team,
Shotaro
Hello Shotaro,
Here is the equation for setting the charge current. The charge current is dependent on the VISET value. Without the knowing the VISET value I can't determine the RSR value, but you will be ableto dermine the value using this equation.
Christian.
Hello Christian-san,
Thank you for the comment.
Is VISET value corresponding to VREF value and it should be set under 2V, right?
Shotaro
Hello Shotaro,
It refers to the voltage set through a voltage divider from VREF to ISET and to GND. Yes, it should be set to 2V or lower.
Christian
