TPS1H100-Q1: ST pin max leakage in inactive state
Part Number: TPS1H100-Q1
A customer had a question regarding the Version A of the TPS1H100. There is a open-drain diagnostic status output pin (ST pin) on this version. The data sheet specifies the max voltage for this pin in the active state, but doesn't show that max leakage in the inactive state. Would it be safe to use the leakage specified for the CS pin? If not, what would be the leakage to use for the ST pin in the inactive state?
Kevin
