I am wondering if the 3% total accuracy includes the error due to the FB pin bias current? (Assuming the datasheet recommendations are followed to select the FB resistor)
Matt
Matt
Hi Matthew,
Suggest you choose bottom FB resistor <500kohm, and error due to the FB pin leakage current will be <1%. And the smaller resistance, the smaller error due to FB leakage current. So it should be no problem to get +/-3% total accuracy.
Jing
