We bought TI USB Interface adaptor (called USB-TO-GPIO2 as per www.ti.com/.../USB-TO-GPIO2) in order to reprogram the TI power controllers on VC707 (as mentioned in support.xilinx.com/.../56811)
We are following the instructions described in VC707_Power_Controllers_Reprogramming_Steps.pdf, and using the MFR tool from this location : www.ti.com/.../FUSION_MFR_GUI
We are unable to program the device as the SW utility from TI reports "Manufacturing Failed" and "No Adapters Found". The adaptor LED is glowing "Green", looks like the adapter Module is all fine.
How can we proceed with the same? we are doubting something wrong with VC707 Power Controller values, need to reprogram it and we badly need the Setup to work. Can you please help with this?
PFA screenshot of the GUI for reference.
