BQ34Z100-G1: Chemical ID Selection
Part Number: BQ34Z100-G1
Other Parts Discussed in Thread: GPCRB
I performed a log of charge/discharge cycle for an NiMH pack battery to determines the chemestry ID with Gauging Parameter Calculator (GPC).
In the repport file, the identified chimistry is LiCoO2, can this be possible ?
Caracteristics of my pack battery are following:
Voltage : 8400mV
Capacity : 2600mAh
cell number series : 7
 I attached the log data of the cycle
ProcessingType = 2
NumCellSeries = 7
ElapsedTimeColumn=2
VoltageColumn = 3
CurrentColumn = 4
TemperatureColumn = 6
2260.roomtemp_rel_dis_rel.csv
    I send 2 new log files to GPC to get the chem ID of my battery, I get attached repports with differents chems ID.
    I started learning cycle with the chem 6107 wich is from the same manufacturer but with not the same capacity, without succes.
    https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1261445/bq34z100-g1-learned-status-doesn-t-update-after-charge-cycle/4775706#4775706
    Can I send samples of my pack battery to Ti for caracterization ?
    If yes how and how can I do that ?
    0	0	0
    0	0	0
    0	0	0
    0	0	0
    0	0	0
    0	0	0
    0	0	0
    0	0	0
    0	0	0
    0	0	0
    0	0	0
    0
    Summary of all IDs with max. DOD deviation below 15%
    Chem ID	max DOD error, %	Max R deviation, ratio
    6117	5.85	0.32
    6116	7.37	0.49
    643	11.97	0.16
    Max. deviations for best ID is within recommended range. Chosen best chemical ID is suitable for programming the gauge.
    Selection of best generic ID for ROM based devices like bq274xx
    Device / Family #1
    Generic Chem ID	Device/ Voltage/ Chemistry	max DOD error, %
    312	bq27421-G1B: 4.3V LiCoO2	200
    354	bq27411-G1C: 4.35V LiCoO2	200
    3142	bq27421-G1D: 4.4V LiCoO2	200
    128	bq27421-G1A: 4.2V LiCoO2	200
    Best generic ID 312
    Warning: Generic ID Deviation is so high that it is most likely due to anomaly in the data. Please check that data files have recomended format, units and test schedule
    Device / Family #2
    1210	bq27621:  (ALT_CHEM1) 4.3V LiCoO2	100
    354	bq27621:  (ALT_CHEM2) 4.35V LiCoO2	200
    1202	bq27621: (default) 4.2V LiCoO2	200
    Best generic ID 1210
    Device / Family #3
    3230	bq27426: (default) 4.35V LiCoO2	100
    3142	bq27426: (ALT-CHEM2) 4.4V LiCoO2	200
    1202	bq27426: (ALT_CHEM1) 4.2V LiCoO2	200
    Best generic ID 3230
    0	0	0
    0	0	0
    0	0	0
    0	0	0
    0	0	0
    0	0	0
    0	0	0
    0	0	0
    0	0	0
    0	0	0
    0	0	0
    0	0	0
    0
    6117	5.85	0.32
    6116	7.37	0.49
    643	11.97	0.16
    Device / Family #1
    Best generic ID 312
    Device / Family #2
    Device / Family #3
  • Hello Mahfoud,
    6117 is the best matching chemID and it is NiMH
  • Hi Shirish,
    Last night I did a new log file, I get attached report file, so I will strat new learn cycle with the chem ID 6117.
  • Hi Shirich,
    The learn cycle with chem ID doesn't succed. I get learned status = 4
    I performed the cycle as : full discharge - Relax - full Charge - Relax - full discharge and Relax as specified in the technical data.
    I attached the log data if you can help tu understand what happen !
    Using the GPC tool, I did an Optimized Impedance Track Parameters, the GPC returned the Ra table but not gg_out.csv, how can I resolve that ?
    24082023_NiMH-report_process_2.zip24082023_NiMH-report_process_3.zip24082023_NiMH_log.zip
  • Hello Mahfoud,
    Use the GPCRB tool when using gg.csv
    The discharge must use 90% of battery/design capacity for proper learning.
  • Hi Shirish,
    Thanks for your help. Indeed I calculated the discharge capacity and it's very low 68.9%
    I get learned status = 6 for the NiMH battery with some changes in the configuration, but with the new configuration I don't get the FC flag and estimated  full charge capacity is very low 453mAh !
    I run a new learn cycle, can you have a look on data ?
    8270.20230831_NiMH_2600mAh.zip
