TPS6594-Q1: How to release the EN_DRV
Part Number: TPS6594-Q1
Hi, TI supporter
I want to know the steps to pull high the EN_DRV.  Currently its always low after startup, write to register 0x80 doesn't work
I find in the usre manual that only when all other interrupts are cleared, I can set the EN_DRV to high. I want to know what these all other interrupts are? If the register INT_STARTUP(0x65) are included. INT_STARTUP is 0x02 after startup, I want to clear it but when I write 0x02 back to INT_STARTUP, the PMIC shut down.
Thank you!
Zhihua
