BQ51050B: Charging Issue
Part Number: BQ51050B
Hi There,
The issue I currently have is that when the unit is placed onto the charger it begins to charge the battery until full (as expected) and then switches off. The problem is that the battery will then start to deplete while on the charger and will not start charging again unless I physically lift the unit off the charging pad and place again. If I don’t lift it off the pad the battery will completely go flat and still will not restart charging.
Just wondering if there is any option we can do with the IC that allows for charging to restart on its own when the battery voltage starts to drop (when left on the charger).
