As my PCB size is small so i would like to select compact size component as possible.
I am not sure What is the maximum current on the BST pin? so i can choose appropriate size of R6, as marked in below's application circuit. Will a R0201 package works fine here?
And, since it is a 0 ohm resistor, what is the purpose of putting this resistor here?
Thank you very much.
/Roland
