I use bq24104 following the circuit from datasheet, the charging current ,charging voltage are all right with my setting.
The output of PG pin is right, but the output indications pins: STAT1 & STAT2 are always wrong, (there are 4.7k pull up resistor to STAT1 & STAT2 )
I replaced bq24104 with bq24103A, the outputs of STAT1 & STAT2 are always wrong,too.
Could anyone help me ?
Thanks very much!
