We had tested the UCC23513 of the input and output performance. We find the If current have slightly high at turning high, and has slightly ringing at turning off. The turning off ringing also cause the output voltage has the same ringing. May I consult you that is a problem or not? What is reason causing that?
Regards, Gary
CH1 Isolator input ( Pin1對Pin3 )
CH2 IF input current
CH3 Isolator output ( Pin5對Pin4 )
Turn-on:
Turn-off
Full-screen
