hi, Dice,
same question reply to you ,LMR54410 LMR50410 can replace the LMR14010A. we have a new product LMR51610 is the same.
Elena
Hi Elena,
Thank you for your reply.
There is no description of "Replacing Non Sync Converter" in the data sheet "SLUSDW3A" of LMR50410.
I would like the description to be updated to be similar to other devices.
Dice-K
hi, Dice,
emm, maybe we could not do this update, because for most sync device the LS mos could parallel with a diode, compare the resistor of this two part, that means we will update almost all DS sync to no sync ?
My way is let customer refer to LMR54410 or LMR51610 if target update no-sync to sync, and confirm the other device should be the same. Now as I know only this two part have the section of sync and no-sync .
Elena
