AP6503SP-13, MCP1501-25E/SN, MCP1727-3302E/SN, MIC4576-5.0WU, MIC4576-5.0WU, MIC4576WU, MIC4724YMME P2P Replacement
Other Parts Discussed in Thread: TPS54336A
Hi all,
I am looking for P2P replacements for AP6503SP-13, MCP1501-25E/SN, MCP1727-3302E/SN, MIC4576-5.0WU, MIC4576-5.0WU, MIC4576WU, and MIC4724YMME.
Could you give me some help?
Sincerely,
Karen
  • Hello Karen,
    I highly recommend assigning the other devices to their product lines on a separate post with proper Responsible Organization. You will get faster response.  Our Team in LOW Current will look into the MV Buck devices
    Thanks!
    Tahar
  • Hi Karen,
    Per Tahar said, please create different threads of each part and assign to right product line to answer your question.
    Seems only AP6503 (23V 3A Buck) should our product line (Middle-Vin buck) look at. I found TPS54336A is the p2p alternative. But seems AP6503 Vref is 0.925V, while TPS54336A Vref is 0.8V, the Rfb values could be different.
    For other parts, MCP1501 and MCP1727 are LDO; MIC4576 is 36V buck (you should reach Wide-Vin Buck product line); MIC4724 is 6V buck (you should reach Low-Vin Buck product line.)
