Hello TI expert,
We are using TI LP8860 backlight chip, in our design we make the Cathnod of the 3x LED strings shorted together in display side as below picture.
Check the LP8860 datasheet seems connecting the LEDs Cathnod separatly is recommanded. The questions are as below, could you please check and comment? Thanks a lot.
1. What will be the disadvantage or risks if we connect make LEDs Cathnod shorted together?
2. Is it mandatoty to separate the LEDs Cathnod?
3. What is the benifit if we separate the each LED string Cathnod ?
3, Is there any special setting we need take care to mitigate the risk/disadvantage of shorting LEDs Cathnod together? in our design, it is close to PV build, we don't have time to change the design. And in the previous HW validation test, we didn't find any backlight issues.
