Other Parts Discussed in Thread: BQ27220, BQSTUDIO, EV2400
Hope you are doing well.
We are using BQ27220EVM-744. Without load remaining capacity(RC) 1119mAh show higher but after load connect it goes to 89mAh. in sequence aging remove load readings show after 89mAh.
if we remove battery and connect again reading follow upper sequence(without load 1119mAh, with load 89mAh....)
Could you please tell us this are correct or not because we calculate percentage using remain capacity?
is there any other option to get or calculate battery percentage?
Please find attached readings for your reference.
05-09-2023
Serial port COM5 opened
Time Count(per 10sec) 23 BQ27220 Voltage = 0 mV Current = 0 mA RC = 0 TTE = 0 TTF = 0
Whithout load
Time Count(per 10sec) 24 BQ27220 Voltage = 3609 mV Current = 0 mA RC = 1119 TTE = 65535 TTF = 65535
Time Count(per 10sec) 25 BQ27220 Voltage = 3609 mV Current = 0 mA RC = 1119 TTE = 65535 TTF = 65535
Time Count(per 10sec) 26 BQ27220 Voltage = 3609 mV Current = 0 mA RC = 1119 TTE = 65535 TTF = 65535
Time Count(per 10sec) 27 BQ27220 Voltage = 3609 mV Current = 0 mA RC = 1119 TTE = 65535 TTF = 65535
Time Count(per 10sec) 28 BQ27220 Voltage = 3609 mV Current = 0 mA RC = 1119 TTE = 65535 TTF = 65535
Time Count(per 10sec) 29 BQ27220 Voltage = 3609 mV Current = 0 mA RC = 1119 TTE = 65535 TTF = 65535
With load
Time Count(per 10sec) 30 BQ27220 Voltage = 3609 mV Current = -85 mA RC = 210 TTE = 1145 TTF = 65535
Time Count(per 10sec) 31 BQ27220 Voltage = 3569 mV Current = -239 mA RC = 89 TTE = 43 TTF = 65535
Time Count(per 10sec) 32 BQ27220 Voltage = 3569 mV Current = -238 mA RC = 89 TTE = 30 TTF = 65535
Time Count(per 10sec) 33 BQ27220 Voltage = 3568 mV Current = -238 mA RC = 88 TTE = 25 TTF = 65535
Time Count(per 10sec) 34 BQ27220 Voltage = 3567 mV Current = -238 mA RC = 87 TTE = 23 TTF = 65535
Time Count(per 10sec) 35 BQ27220 Voltage = 3567 mV Current = -237 mA RC = 87 TTE = 23 TTF = 65535
Time Count(per 10sec) 36 BQ27220 Voltage = 3566 mV Current = -237 mA RC = 86 TTE = 22 TTF = 65535
Time Count(per 10sec) 37 BQ27220 Voltage = 3566 mV Current = -237 mA RC = 85 TTE = 22 TTF = 65535
Time Count(per 10sec) 38 BQ27220 Voltage = 3566 mV Current = -237 mA RC = 85 TTE = 22 TTF = 65535
Time Count(per 10sec) 39 BQ27220 Voltage = 3565 mV Current = -237 mA RC = 84 TTE = 21 TTF = 65535
Whithout load
Time Count(per 10sec) 40 BQ27220 Voltage = 3603 mV Current = 0 mA RC = 83 TTE = 24 TTF = 65535
Time Count(per 10sec) 41 BQ27220 Voltage = 3603 mV Current = 0 mA RC = 83 TTE = 45 TTF = 65535
Time Count(per 10sec) 42 BQ27220 Voltage = 3603 mV Current = 0 mA RC = 83 TTE = 89 TTF = 65535
Time Count(per 10sec) 43 BQ27220 Voltage = 3604 mV Current = 0 mA RC = 83 TTE = 178 TTF = 65535
Time Count(per 10sec) 44 BQ27220 Voltage = 3604 mV Current = 0 mA RC = 83 TTE = 356 TTF = 65535
Time Count(per 10sec) 45 BQ27220 Voltage = 3605 mV Current = 0 mA RC = 83 TTE = 711 TTF = 65535
Time Count(per 10sec) 46 BQ27220 Voltage = 3605 mV Current = 0 mA RC = 83 TTE = 1245 TTF = 65535
With LED load
Time Count(per 10sec) 47 BQ27220 Voltage = 3605 mV Current = -7 mA RC = 83 TTE = 1245 TTF = 65535
Time Count(per 10sec) 48 BQ27220 Voltage = 3605 mV Current = -7 mA RC = 83 TTE = 1245 TTF = 65535
Time Count(per 10sec) 49 BQ27220 Voltage = 3605 mV Current = -7 mA RC = 83 TTE = 711 TTF = 65535
Time Count(per 10sec) 50 BQ27220 Voltage = 3605 mV Current = -7 mA RC = 83 TTE = 711 TTF = 65535
Whithout load
Time Count(per 10sec) 51 BQ27220 Voltage = 3607 mV Current = 0 mA RC = 83 TTE = 1245 TTF = 65535
Time Count(per 10sec) 52 BQ27220 Voltage = 3607 mV Current = 0 mA RC = 83 TTE = 2490 TTF = 65535
With load
Time Count(per 10sec) 53 BQ27220 Voltage = 3569 mV Current = -238 mA RC = 83 TTE = 111 TTF = 65535
Time Count(per 10sec) 54 BQ27220 Voltage = 3567 mV Current = -237 mA RC = 83 TTE = 36 TTF = 65535
Time Count(per 10sec) 55 BQ27220 Voltage = 3566 mV Current = -237 mA RC = 82 TTE = 26 TTF = 65535
Time Count(per 10sec) 56 BQ27220 Voltage = 3565 mV Current = -237 mA RC = 81 TTE = 23 TTF = 65535
Time Count(per 10sec) 57 BQ27220 Voltage = 3565 mV Current = -237 mA RC = 81 TTE = 22 TTF = 65535
Time Count(per 10sec) 58 BQ27220 Voltage = 3565 mV Current = -236 mA RC = 80 TTE = 21 TTF = 65535
Time Count(per 10sec) 59 BQ27220 Voltage = 3564 mV Current = -236 mA RC = 79 TTE = 20 TTF = 65535
Time Count(per 10sec) 60 BQ27220 Voltage = 3601 mV Current = 0 mA RC = 79 TTE = 22 TTF = 65535
Time Count(per 10sec) 61 BQ27220 Voltage = 3602 mV Current = 0 mA RC = 79 TTE = 44 TTF = 65535
Serial port COM5 closed
Time Count(per 10sec) 74 BQ27220 Voltage = 3605 mV Current = 0 mA RC = 79 TTE = 65535 TTF = 65535
Time Count(per 10sec) 75 BQ27220 Voltage = 3605 mV Current = 0 mA RC = 79 TTE = 65535 TTF = 65535
Remove Battery
Time Count(per 10sec) 76 BQ27220 Voltage = 2997 mV Current = 2997 mA RC = 2997 TTE = 2997 TTF = 2997
Time Count(per 10sec) 77 BQ27220 Voltage = 3700 mV Current = 0 mA RC = 0 TTE = 0 TTF = 0
Time Count(per 10sec) 78 BQ27220 Voltage = 3606 mV Current = 0 mA RC = 1096 TTE = 65535 TTF = 65535
Time Count(per 10sec) 79 BQ27220 Voltage = 3606 mV Current = 0 mA RC = 1096 TTE = 65535 TTF = 65535
