Hello expert,
Do you have CSD16415 VDS spec for min and max? Thanks a lot!
Ann Lien
Hello expert,
Ann Lien
Hello Ann,
Thanks for the inquiry. The FET datasheet specifies the absolute maximum VDS = 25V on page 1. The minimum breakdown voltage, BVDSS = 25V is specified in the Electrical Characteristics table on page 3 of the datasheet. There is no specified minimum operating voltage. However, a high enough (>0.7V) negative drain-to-source voltage will forward bias the intrinsic body diode and it will conduct current. Please let me know if you have any additional questions.
John Wallace
TI FET Applications
Hello John,
Thanks for your reply! May we know if you meaning is that we need to be higher than -0.7V? Could you provide the specific spec for us? Thanks!
Ann Lien
Hello Ann,
Every power MOSFET has an intrinsic body diode, a PN junction, between drain and source. This is how the MOSFET blocks voltage when it is in the off state. A voltage applied from source to drain will forward bias the diode and it will conduct current. Please see Figure 9 in the datasheet which shows the forward drop versus current at 25″C and 125°C.
John
Hello John,
Does it mean the red circle way for the worst case which is around -0.7V? Thanks!
Ann Lien
Hello Ann,
Figure 9 in the datasheet shows the V-I and temperature characteristics of the MOSFET body diode. I'm not sure what you are asking for? TI does not specify a minimum VDS operating voltage for our FETs. We only spec an absolute maximum VDS = 25V and a minimum BVDSS = 25V. Applying a negative voltage between drain and source when the FET is off will forward bias the body diode and current will flow thru it.
John
Hello John,
Customer just want to know when they tested this MOSFET, how can we determine the negative spike is okay or not. So I just want to know the spec that customer can easily compare with waveform to know the spike is okay or not. Do you have this spec for us? Thanks!
Ann Lien
Hi Ann,
Please ask the customer to share their application details and waveforms and we will review them. Would it be possible to get the portion of the schematic with the FETs?
John
Hi Ann,
Were you able to get more information from the customer? Please let me know. I'd be happy to review their design and operating waveforms.
John
Hi Ann,
Since I have not heard back from you, I assume your issue has been resolved and will close this thread.
John
