Hi Team,
A Schottky diode is recommend at the Vout to limit the negative voltage, and protect the IC. Could you pls comments on the how to select the right diode? Thanks!
Hailiang
Hi Team,
Hailiang
Hi Hailiang,
What's the current limit set point?
Hi Avishek,
I see the guidance in the TPS2598x datasheet. Is there any other comments?
Hailiang
Hi Hailiang,
Same guidelines are applicable here also.
In addition to that, please add this below secondary protection circuit as well.
