Hey,
I am using the TPS65273VRHHT voltage regulator. When I power down the regulator with either setting the enable to low or disabling the output via writing to a register I see a weird RC discharge curve.
I was wondering if this is normal behavior or a design problem on my end and how I can fix this. I setup the eval board for this regulator and saw the same behavior as channel 2(my board) on both channel 1 and 2 of eval
board.
Channel 1 (1.8V)
Channel 2 (1.05V)
Here is a picture of our setup
