Part Number: MULTIPKGLDOEVM-823
Could you offer the info. about the PCB size since TW customs needs it for customs clearance!
Brian
Brian
Hi Brian and Ted,
I measured a PCB with an LDO (SOT-23), 5 test points, 4 banana connectors, a 3 pin header with shunt, and 2 capacitors installed. The weight with these components installed is 22 grams.
The area is 51mm x 75.5mm not including the banana connectors.
The area is 86mm x 75.5mm including the banana connectors.
Stephen
