Other Parts Discussed in Thread: LM5149, LM25149-Q1EVM-2100
While datasheet mentions that for all NC (No connect) pins - Connect to GND at exposed pad to improve heat spreading , not a single reference design example follows that guideline. Is there a specific reason ?
Also I am using LM5148 in IBB(inverted buck boost) configuration to generate negative voltage from positive input supply. My exposed pads are connected to negative supply (Not GND). can I connect all NC (No connect) pints to exposed pad that is connected to negative output supply
