Other Parts Discussed in Thread: BQ2432, BQ24232EVM
Hello, I have designed a custom board using BQ24232HARGTT. When the board is switched off, the battery has a consumption of aroud 600uA. May you tell me where may be the problem?
I have tried to remove all the resistors and cut-off the out signal but the current remains. If I remove the BQ2432 the current finally drops to 2uA.
This is the design (pgood and chg signals are directly connected to a uC, viset route is cut on the board hence it should not affect):
please, let me know any aspect to consider because we need to send the board for production as soon as possible.
