Part Number: TPS6593-Q1
Other Parts Discussed in Thread: TPS6594-Q1
Hello support team,
we would like to better understand the functionality of "DISABLE_WDOG" ( currently assigned to GPIO8 in our PMIC configuration):
let is assume the wdg is per default disabled. At each startup the MCU sends an SPI sequence to PMIC to enable the QnA watchdog, and starts serving it.
Now during run time we pull GPIO8 to request "DISABLE_WDOG",:
- Question-1: Does this action disable QnA mode, disable WD_EN bit or the reset reaction ? we assume that the MCU keeps serving the QnA after pulling GPIO8 ( unaware of the pulling action).
- Qeustion-2: if the answer is NO ( no effect, QnA keeps running), then what if we reset the Ecu, and pull GPIO8 while QnA still disabled. Once MCU is powered up, will it manage to activate the QnA in this case ?
Wajdi
