Hi Team:
I would like check TPS7B7702QPWPRQ1 Diagnostic function ( Short to Battery , open load , Shor to GND) is still work if the LDO disable status (EN =low) ?
thank you
Roy
Hi Team:
thank you
Roy
Hi Roy,
If EN=low then the output of the LDO will be off. As there will be no voltage on the output, there will be nothing to pull diagnostics from.
Stephen
