Other Parts Discussed in Thread: LP5524, TLC59283
Hi
RnD have tested LP5012. Because RnD application is needed to turn on/off LED fast, RnD found if he used EN pin to turn on/off LED, he needed to config register again after turn on LP5012.
It is not able to meet spec requirement. He looks for solution that turn on/off LED by I/O pin and doesn't reconfig registers after turn on/off LED. Do you have any suggestion for this application?
Thanks & best regards,
